big idler swap?
emichaelhaynes
big idler swap?
Post by emichaelhaynes » Wed Aug 29, 2007 5:10 am
any reason why one of the solid disk front idlers from, say for instance, a 350 fit, uh, maybe a 440? found several very old cracks on one of mine. not too happy about it. tend to push things a bit. any new crack might go all the way through...
somebody got one each they could stand side by side and compare?
could weld it although stress relieving it might be a real bear...
michael
Post by Lavoy » Wed Aug 29, 2007 7:04 am
The idler brackets are different, and axle is quite a bit larger.
Cut the crack out with a torch or plasma cutter, and then weld it back shut.
Users browsing this forum: No registered users and 157 guests
