main bearing set for 40, 420, 430, 440
dtoots1
Post by dtoots1 » Sat Aug 17, 2024 8:49 am
Is anyone having luck finding these danged things????
Or somebody have a spare set willing to sell???
Latest word i get is now put off to October!!
gus
Re: main bearing set for 40, 420, 430, 440
Post by gus » Sat Aug 17, 2024 1:51 pm
Any way to cross reference to every known bearing dimension??
Long shot.... used bearings? Not sure if it is better than nothing but....
dtoots1
Post by dtoots1 » Sun Aug 18, 2024 7:26 am
clevite shows...same diameter mains for 2014 thru 2018 silverado 1500..as ours
dont know how to get rest of dimensions...i have actual dimensions of what is needed as follows:
#1 needs 1.836 wide
Thrust between shoulders 2.093
Outside of shoulders 2.275 up to minus .005
main shaft 2.386
If needed can get crank to match diameter of bearings
Wilbur
Post by Wilbur » Tue Aug 20, 2024 5:38 am
Can't help you but feel your pain!
1959 440 icd 831 loader
1961 1010 dozer
dtoots1
Post by dtoots1 » Sun Aug 25, 2024 7:47 am
Have you any info on mains made by Reliance Power Parts as to reliability etc??????
Post by Lavoy » Sun Aug 25, 2024 10:47 am
They do not manufacture anything, so they are out of stock just like everybody else I would assume.
gaspumpsam
Post by gaspumpsam » Wed Sep 04, 2024 7:42 am
Try Egge machine company , in California. They might have, or can make bearings. Dont know the contact number, but they should be on line now.
dtoots1
Post by dtoots1 » Wed Sep 04, 2024 5:24 pm
Called them on phone couple months ago...said NOT
dtoots1
Post by dtoots1 » Sat Sep 07, 2024 9:54 am
What engine will fit the 420s??
Will any of the 440 gas work ok???\\
The ongoing SAGA continues...
Does ANYBODY have a good used resonably priced 2 cylinder gas engine to fit my 420?
I would certainly like to get this thing up and running and out of my way in the garage...
Once again I checked and now they saying Mid December for the mains..no response to the machine shop either!...AS IF!!!
PM me.
Post by Lavoy » Tue Sep 10, 2024 9:06 am
There is no known delivery date for main bearings, the people you are talking to have no idea what they are talking about, they are only guessing. The delivery date has been August of every year for the last 2 years, now they are just telling you December. Your machine shop is never going to hear anything, they are talking to a Clevite jobber, and Clevite has discontinued these bearings, and no longer catalogs them, so it is highly unlikely they will ever hear anything.
All two cylinder gasses will fit, but depending on engine, you will need to change a lot of other parts.
dtoots1
Post by dtoots1 » Tue Sep 10, 2024 6:59 pm
OK
THANKS
D
gaspumpsam
Post by gaspumpsam » Sat Sep 14, 2024 7:46 am
dtoots1- give me a call- Sam, 250-983-4347 , and or message me. scork@goldcity.net re main brgs for 420 jd
dtoots1
Post by dtoots1 » Sun Sep 22, 2024 9:01 am
Well then...another question...
Does anyone have a used crank that will fit the .010 bearings-- i have a possibility of one set of used mains for this size..my crank will fit the .030 mains but have not located bearings as yet....
getting down to me wanting to use my old mains and see how long they last....maybe try to refurbish somehow ????
send me a PM
gaspumpsam
Post by gaspumpsam » Mon Sep 30, 2024 11:18 am
I have good used set std main bearings for your engine, if that helps- ( for anyone )
dtoots1
Post by dtoots1 » Mon Sep 30, 2024 1:19 pm
Gaspumpsam,
What size bearings do you have...i need .030...do you have good crank to match yours?
And am seriously thinking of putting my old ones back in....only thing that will happen is either crank gets woen or bearings go..
Users browsing this forum: KPaXz and 200 guests
