John deere 350b only cuts one way
James1992
Post by James1992 » Wed Feb 28, 2024 6:36 pm
I can pull the left cutting lever and the right side will not push it around or if you push heavy the right side doesn't track
Re: John deere 350b only cuts one way
Post by Stan Disbrow » Thu Feb 29, 2024 8:15 am
So, the right side steering clutch is toast from the sounds of it.....
James1992
Post by James1992 » Thu Feb 29, 2024 2:27 pm
The right side just got a complete rebuild
dtoots1
Post by dtoots1 » Thu Feb 29, 2024 3:05 pm
Then would appear to be adjustment problem...unless something came undone or not accomplished????
need more info
Post by Jim B » Thu Feb 29, 2024 4:06 pm
Pulling a lever disengages the steering clutch and applies the brake, the opposite side should continue to drive, to turn the crawler in the direction of the pulled lever.
You pulled the left lever, it stopped driving. The right was supposed to keep turning to "push" the crawler to the left. You also said, " if you push heavy the right side doesn't track". From your description it does not matter that "The right side just got a complete rebuild", something was not done correctly, is way out of adjustment, or has failed on the right side.
Did you do the rebuild of the right side? What was done and what was replaced? Do you have the Service Manual and Operator's Manual for your machine?
James1992
Post by James1992 » Thu Feb 29, 2024 6:00 pm
Yes I done it myself have all service manuals I replaces all clutches bearings pressure plate
Post by Jim B » Thu Feb 29, 2024 6:50 pm
What was the reason that you overhauled the right steering clutch?
Did you use the JD7 gauge to set the pressure plate fingers when you assembled it? As dtoots1 mentioned, try a complete step by step adjustment of the steering clutch and brake. Rule adjustment error or slippage out before tearing it down.
This is a dry steering clutch 350B, correct?
Any oil or water in that steering compartment?
James1992
Post by James1992 » Thu Feb 29, 2024 6:55 pm
Yes dry steering clutch I have the Guage to set pressure plate and it was doing the same thing is why I done a reb8on that side
Post by Jim B » Thu Feb 29, 2024 7:20 pm
Did you check the condition of the splines in the hub the ring gear rides on and on the shafts, out and through, the final drive?
Does it have power assist steering and is all in related linkages moving properly?
How many steel discs and how many friction discs did you install?
James1992
Post by James1992 » Thu Feb 29, 2024 8:14 pm
I check all splines it has power assit all parts seem to move like they should I belive it was 8 fibers and same steel plates
original possum
Post by original possum » Fri Mar 01, 2024 9:36 am
If you have free travel of the throwout bearing (from ALL fingers) and it still slips you have no option other than tearing it down. If so and assembly is good then suspect the pressure plate springs first.
Post by Lavoy » Sat Mar 02, 2024 11:36 am
Did you use Ebay parts? My apologies if you got them from me and I just don't recognize you.
James1992
Post by James1992 » Sat Mar 02, 2024 1:12 pm
No I got them from reliable aftermarket parts
Post by Lavoy » Mon Mar 04, 2024 12:23 am
Same difference, 90% of the clutch parts on ebay are them. I would say junk pressure plate all things being equal. I know their pressure plates, thrown a couple new ones in the scrap dumpster.
Post by Stan Disbrow » Mon Mar 04, 2024 8:30 am
And then all the reports of (s)crap fiber discs as well.....
A virtual minefield....
