420C right steering clutch slippage.
JerryB4
Post by JerryB4 » Sun Jan 21, 2024 6:59 pm
new development in steering department. I suspect new clutches are in order but interested in other thoughts.
I have had no problems with right steering clutch untill last summer, would work fine at first but the longer I ran dozer the more slippage I experianced.
By the end of 1-1/12 hrs when pushing a reasonable amount, right clutches pretty much became nonfunctioinal, repeated a couple of times so wasn't a fluke.
I replaced left side (thanks Levoy) a couple of years ago due to slipping from the getgo not relating to time under use. So I am wondering if anyone has thoughts on what is causing slippage only when it gets warm?
Thanks.
Re: 420C right steering clutch slippage.
Post by Jim B » Mon Jan 22, 2024 6:36 am
A couple thoughts, easy checks for starters.
How is the adjustment?
Take the cover off the steering clutch compartment and look inside to see if things are contaminated.
Post by Lavoy » Mon Jan 22, 2024 3:06 pm
Often times it is oil contamination, which tends to get worse as the clutch gets warmer.
JerryB4
Post by JerryB4 » Mon Jan 22, 2024 10:39 pm
Thanks guys, going to look down there tomorrow with a line camera, suspect I will
find contamination. More questions to come I'm sure.
Users browsing this forum: Google Adsense [Bot] and 35 guests
