Monitor AT10073 12v
jmcarrol
Monitor AT10073 12v
Post by jmcarrol » Sun Oct 01, 2023 4:06 pm
    Anyone ever repaired the monitor on a 650g?
    AT100073 is the part number. Not sure why mines not working and where would you look to buy this part.
    Re: Monitor AT10073 12v
    Post by Jim B » Sun Oct 01, 2023 4:39 pm
    Do you have the two technical manuals for the 650G? TM1403 Operation and tests technical manual and the TM1404 Repair technical manual are the two required. If it is not working, it could be as simple as a power supply or ground issue. The TM1403 should have wiring diagrams and info on operation and testing for power, ground, etc. to diagnose if the monitor, or some components, are bad. TM1404 may have some info on the monitor/system physical repair.
    There are some places that repair monitors, at least the ones for Ag equipment. An internet search for "John Deere AT10073 monitor repair" should bring up at least a couple places you could contact. You would need to ask your JD Construction equipment dealer if there is a JD repair service for them or if there is someone they use. JD likely still has new monitors available for sale.
    jmcarrol
    Post by jmcarrol » Mon Oct 02, 2023 2:12 pm
    I have the manuals ordered and they should be here this week. Thank you for the information
    Users browsing this forum: No registered users and 244 guests
