tranny gunk
make do homesteader
tranny gunk
Post by make do homesteader » Fri Mar 03, 2023 5:10 pm
JD450 b : I'm cleaning the tranny filter basket. It's full of green slime, sludge, and particulate. Can I use diesel fuel to rinse out the tranny with out damaging anything internally? I've got some high end shifting issues and this seems to be a good place to start. I also don't want to contaminate all the new oil when I fill it! Can the range change cover be removed and the clutches be rinsed from the top down? Thanks
LeonardL
Re: tranny gunk
Post by LeonardL » Sun Mar 05, 2023 8:55 am
Yes you can remove the cover and no you won't hurt anything by using diesel fuel to rinse / clean things. When you do refill the transmission I would add a can or bottle of anti fungal / bacteria treatment as well. The slime or gunk is actually a bacteria / fungus that will grow in petroleum products. I would also add it to your fuel tank as most likely it's in there as well.
make do homesteader
Re: tranny gunk
Post by make do homesteader » Sun Mar 05, 2023 5:18 pm
Thanks Leonard, I'll do that. Good next step in this rehab.
Users browsing this forum: Jim B and 208 guests
