Parts numbers and schematic for hyd. pump?
make do homesteader
Post by make do homesteader » Fri Feb 17, 2023 9:20 am
My parts manual for a 450 b does not have the hydrolic pump schematic or parts numbers. The tech manual has a repair drawing but no parts numbers. Where may I find the complete schematic and parts numbers for the hyd. pump on the front of the engine?
Thanks for your help!
Re: Parts numbers and schematic for hyd. pump?
Post by Jim B » Fri Feb 17, 2023 10:37 am
You need a parts catalog for your blade. I think you said a while back you have a 6 way. That should mean you have a model 6405 6 way inside push frame blade. You need parts catalog # PC919 for the 6405 blade and related hydraulics. Thought I gave you that before. Anyway, here is a link to the online parts catalog for the 6405 Bulldozer. HTH
PC919
make do homesteader
Post by make do homesteader » Mon Feb 20, 2023 8:44 am
Thanks Jim, I didn't realize the pump info was in the blade parts manual. I appreciate the note.
Users browsing this forum: Jim B and 202 guests
