Reverser operation?!?!? How too
One of what Im sure will be stupid questions...Picked up my 59 430C today and literally the 1st time ive ever sat on one was when I backed it off the trailer..My Question is HOW do I use the reverser?!?!..I pushed in clutch put it in 1st and pulled reverser to reverse and with clutch still in the tractor moves..is that right??..What did i do wrong
Re: Reverser operation?!?!? How too
It should not move in either reverse or forward with the engine clutch pedal pushed (disengaged). Does it move forward if in 1st and the reverser in forward? Sounds like an engine clutch issue, as disengaging the engine clutch should stop the drivetrain from the clutch disc back. First thing would be to go through the engine clutch adjustment.
I didnt think so..made no sense ..Ill look at it and see more..Thank you for the infoJim B wrote: ↑Tue Nov 08, 2022 5:47 pmIt should not move in either reverse or forward with the engine clutch pedal pushed (disengaged). Does it move forward if in 1st and the reverser in forward? Sounds like an engine clutch issue, as disengaging the engine clutch should stop the drivetrain from the clutch disc back. First thing would be to go through the engine clutch adjustment.
Users browsing this forum: Lavoy and 24 guests
