I"ll give it a go
ngilles wrote: ↑Sat Oct 06, 2018 6:05 pmHi Guys,
I'm following my usual routines when I buy a piece of equipment. I change all fluids and filters.
I was going through the manual for my straight 555 track loader and found the page for the removal and cleaning of the transmission oil pickup in the bottom of the transmission.
HELP I can't get that sucker out for the life of me and I don't want to break anything. I've posted pics in 3 different ways in this google shared folder. I put notes on the google slides that are in there, saved them as pics and as PDF's. I hope they open right for you:)
https://drive.google.com/open?id=1BfKi1 ... z6Pb3xVCZ4
I'm pretty sure this has never been out of the tractor. I'd really appreciate any help!
Thanks again,
Nick
Hello everyone, new here and wanted to post my experience with my 555A... purchased it about a year ago from a guy in PA (I am in Texas) and the crawler ran pretty good until last week. It would never push over a tree, but I started seeing a loss of power to the tracks. Last Friday, it stopped moving completely. I decided that I needed to change the transmission filter and fluid since I had not really touched it since I bought it. I successfully performed the maintenance and after cranking it back up it would move, but still had no power to the tracks. The bucket hydraulics work fine, just could not dig in to pick up dirt. So I turned to this forum and some others and found some frightening news that my problem was most likely the spider gear that so many have issues with. Well, when I found this post I decided to check my tech manual and see if I could remove the sump screen. I did so over the weekend and what I found was a clogged screen. It was so bad that I could not believe it. I too had issues getting the screen out, but then I read the manual again and found the trick! What you do is push the screen into the transmission (manual reads to the back, but technically the other side) rotate it to the left so that the port that connects to the pickup tube faces the back of the transmission, and simply pull it out. Comes out easily! When re-installing, insert the way you took it out, then rotate it to the right, connect the pickup tube, and you are golden! The worst part was getting the plate back on... nothing that a couple of pry bars cant handle! I had to make my own gasket set, wasn't going to pay $85 / for each gasket... that was crazy. But let me tell you, I almost junked this machine but after cleaning that sump screen, I now get pressure to the gauge (which I thought was broken because it always read 0-30 lbs (in the white)... it has twice the power it had when I got it, it will now mow over trees with easy, and the steering is much improved. So very happy!! Thanks for all the posts and technical advice... I hope my post finds someone with a 555 and helps you!! Take care!!ngilles wrote: ↑Tue Oct 09, 2018 7:39 amSo frustrating lol! Stopped at local JD Const. Equip dealer and they look at me like I'm speaking Chinese. They could look up the cover gasket for me, that was about it. That was after I gave them the part number that I looked up myself at JD online. Same not helpful picture in my T1111 tech manual as online lol. Oh well, not giving up, I'll figure it out!
Users browsing this forum: No registered users and 28 guests
