350 Bottom Roller - Rebuildable?
carpenterguy
Post by carpenterguy » Wed Aug 03, 2022 2:10 pm
I just picked up a late 60's (I think) 350 dozer and am in the process of getting it going. I found that one of (possibly more) the bottom rollers is completely loose as if the bearings in it disappeared. Is it possible to rebuild these rollers or am I stuck paying $400+ for a new roller?
I'm located in Cullman, Alabama
LeonardL
Re: 350 Bottom Roller - Rebuildable?
Post by LeonardL » Wed Aug 03, 2022 6:16 pm
Yes, they can be rebuilt if they aren't shelled out completely. Which is usually the case. If the ones you have are that loose then I would bet they are all toast. Check with Lavoy, the owner of this site. He may be able to help you out since he sells parts for these older machines.
The up side to buying new rollers is they are just about bullet proof. They are sealed and run in oil so you don't have to grease them. Unfortunately the undercarriage and tracks are about 80 percent of a crawlers overall maintenance cost.
Post by Lavoy » Thu Aug 04, 2022 7:50 am
You will find you will be way past the cost of a new roller to rebuild yours. Either the seals are obsolete and not avaialble, or $375/each, plus the shaft and bushings.
$400 is pretty high, I can sell them for less than that.
carpenterguy
Post by carpenterguy » Thu Aug 04, 2022 1:01 pm
Thanks Lavoy, could you get me a price on one? I have a suspicion we'll need more than one but I won't know till this weekend.
Post by Lavoy » Thu Aug 04, 2022 1:31 pm
Shoot me an email when you get a chance, postmaster@jdcrawlers.com
Norbert77
Post by Norbert77 » Mon May 06, 2024 7:54 am
Old thread, but anyone got pics of what the rollers, pins and bushings look like? Someone welded around where the pin is on the side. One of the welds broke and the roller flops around. I'm thinking maybe I can get the roller machined for new bearings. But then I tend to be optimistic
Post by Lavoy » Mon May 06, 2024 8:44 am
What crawler are you referencing?
Users browsing this forum: No registered users and 32 guests
