I just installed a new front crank seal in my timing cover and drove it to the bottom trying to keep it straight. I know the seal I removed was driven flush to the cover surface. Therefore, the seal now sits about 1/8” deeper.
Is this ok?
350B Front Crank Seal
- Al Swearengen
Re: 350B Front Crank Seal
Reckon it should still do it's job since the journal is the same size as 1/8" before it...maybe even better if there was previous wear.
'99 450G 6-Way
Thanks. I know there is the usual wear groove on the shaft, so may sit on pristine surface now. I should be able to tackle getting out to my machine the week.
Users browsing this forum: No registered users and 184 guests
