How to bleed air from a 350c/ or fuel problems
Gwilkrrs
Re: How to bleed air from a 350c/ or fuel problems
Post by Gwilkrrs » Mon May 09, 2022 12:45 pm
thanks-
i will check the return line for mouse poop and will check for a broken wire terminal and then jump it to the positive terminal to check-
thanks all for helping-
i plan on checking the machine this afternoon again.
Gwilkrrs
Post by Gwilkrrs » Tue May 10, 2022 6:18 pm
So I got to the machine today
Yep a wire right out of the top- didn’t see it before
Put test light on and machine fired right up- turned off after a min and light still on
Pulled the reurn line off the pump and started machine, fuel squirted out from pump making a mess but machine ran clear and dint turn off.
Cleaned check valve fitting and put back on- machine started and sounded clear then started to hesitate like before and then turned off
Removed check valve and machine ran clear and stayed running
With machine off fuel kinda built up and oozed out of top of pump with no line connected
I don’t really get the check valve on this as it doesn’t seem to be a check valve I am used to but now to search parts for where to get a new one from
Thanks all
B Town
Post by B Town » Tue May 10, 2022 6:53 pm
The ball inside the check valve is clear. It can be had to see if it is really in there or not. The ones on my machines can be disassembled.
jimmydiesel
Post by jimmydiesel » Tue May 10, 2022 7:40 pm
The problem isn’t the check valve. The check valve is being plugged by little pieces of the dampener ring inside the injection pump.
After many years the dampener ring starts to disintegrate and the pieces plug the check valve.
The dampener ring will have to be replaced.
440 ICD 602 Blade 3Pt.hitch.
440 ICD 831 Loader
440IC 831 Loader
1010c Diesel 612 6 Way Blade
jimmydiesel
Post by jimmydiesel » Tue May 10, 2022 8:05 pm
The black is what is left of the dampener ring. The white is the new ring before installing
440 ICD 831 Loader
440IC 831 Loader
Gwilkrrs
Post by Gwilkrrs » Wed May 11, 2022 4:33 am
i tried to capture the fuel to see if i could find "mouse turds" but i couldnt see anything
i can see the clear ball of the check valve and it seemed to be stuck at first but i am unsure really.
after i ran it without and put back on i didnt see anything in it again?
where is the dampner ring actually at? does the pump come off and apart for this type of repair?
the check valve seemed backward to me as i thought it would allow fuel into pump and prevent it going up the return but i think i am backward in my thinking?
B Town
Post by B Town » Wed May 11, 2022 5:27 am
Check valve is to keep pump full but not over-pressured. Have you confirmed the return line is clear all the way to the fuel tank?. Check vale let’s fuel leave the pump to prevent too much pressure, while keeping the pump full.
Post by Jim B » Wed May 11, 2022 5:41 am
The check valve allows excess fuel out of the injection pump to return to the fuel tank during operation. It also lets air out and prevents fuel or air coming back into the pump.
Another test, to determine if the problem is internal to the pump, is to loosen the two screws holding the small cover plate on the side of the injection pump body enough to let fuel leak out around the plate a bit. If the engine stays running correctly with the fuel leaking out, it is a sign the pellethane flex ring is breaking up and the pump needs repair. You can clean the side of the pump and carefully remove the cover plate with a clean rag below the opening, you may find the moose turds behind the plate. (No parts will fall out.)
If it needs repair, I highly recommend that the injection pump be sent to a shop specializing in that work. I have had some training on them, but I spend the money to have a pump shop do them up right. They will have the correct tooling to repair, test and calibrate it. Yes, you can buy parts. Yes, some people do their own pumps. However, without the right technical info, tools, and equipment, damage can be done which will cost more than sending it to a pump shop would have cost. And they don't have the equipment to calibrate and adjust after repair. Just my opinion, others will vary.
DrLoch
Post by DrLoch » Wed May 11, 2022 6:39 am
If you go to Youtube and put "John deere dozer injector pump" in the search bar you will see a number of video's showing the issue and fix. Some good some not so good.
Make sure you have it timed before you remove it, manual will explain. If you try to repair yourself or have someone you know try, DON"T grab the body of the pump in a vise..... can not overstress this. Make something to mount the pump to. Or send it to someone who knows what they are doing as suggested by others.
450C Track Loader
291457T
DrLoch
Post by DrLoch » Wed May 11, 2022 6:41 am
Here is a good video, https://www.youtube.com/watch?v=OXdYSon ... eswithJosh Don't think he replaced the weight cage.
https://www.youtube.com/watch?v=JHwOi-j ... ctorrepair You will see the cage...
450C Track Loader
291457T
Gwilkrrs
Post by Gwilkrrs » Wed May 11, 2022 6:55 am
i did not test the return line back to the tank-
good catch, i will put some air to it this afternoon to see if its clear (i should see bubbles back at tank if it is i suppose)
thanks for the other checks at the plate and the explanation on the check valve-
Gwilkrrs
Post by Gwilkrrs » Wed May 11, 2022 6:51 pm
Well I took the return line off and blew it clear back to the tank
Started machine with line removed and check valve installed- machine started and sounded clear
Turned machine off and installed return line- started machine and it ran clear for awhile (4 min maybe) then turned off
put a rag under the pump and took the side plate off and got “mouse turds”
The gasket plate is coming apart - damn
now to find a pump repair place and check prices
thanks all
Gwilkrrs
Post by Gwilkrrs » Tue May 31, 2022 8:07 pm
So I had thepumpguy rebuild my pump and I just got it put in and it’s running great now!
jimmydiesel
Post by jimmydiesel » Tue May 31, 2022 8:34 pm
Awesome Always a good feeling when a engine goes from running bad to running good again.
440 ICD 831 Loader
440IC 831 Loader
Users browsing this forum: No registered users and 217 guests
