So I am tossing around getting rid of a rebuilt 440 gas engine out of my parts crawler just seeing if there is any interest.
The engine was rebuilt over 10 years ago and never started , has oil in crank case and was stored inside .
Was told cylinders were bored .090 , crank and head was also reconditioned at that time.
Also includes new manifold and what looks like new clutch and pressure plate.
At some point something was dropped on the water pump and a small piece of the block cracked off topside at water pump mounting flange.
I have the piece and should be a easy repair , more cosmetic than anything .
If I were to install in my crawler I would buy a gasket set and go through top to bottom , but that's just me.
I'm not even sure what this is worth so any input appreciated.
Located in the UP of Michigan.
440 gas engine
Re: 440 gas engine
Wish you where closer
Re: 440 gas engine
You could add your general location to your profile. Someone might know of something in your area, if that info is visible.
Re: 440 gas engine
Engine is still available
- DukeofDeere
Re: 440 gas engine
Is this the one off Drummond Island?
Duke
Duke
Re: 440 gas engine
Western end
Escanaba
Escanaba
Re: 440 gas engine
Duke
Have tried to send you a message , they just hang in my outbox.
Here is my number is you have any other questions
906 280 8478
Mark
906 280 8478
Mark
