2010c sn. 42000 up. To john deere 350 tracks/rails.
My father has owned a 2010c sn58133 for 20 years. Since he has owned it the undercarriage has been fairly worn out and in the past few years looses tracks allot do to the snake in the track. I was looking to stick a bit of money into it because I need to use it and we were looking to upgrade to new jd350 chain or even good used as it is more readily available. What do we have to so to get the 350 track to work on this crawler. Sprockets are worn quite a bit but not totally shot. I've read in other parts of this forum that the 350 track is essentially the same as the late 2010c. I've read that the bushing sizes is what matters the most in this upgrade. I believe the 350 chain is 3? Links short as well? Thanks much.
Re: 2010c sn. 42000 up. To john deere 350 tracks/rails.
2010 of that serial number came with the same links as 350. You will need to find 39 link 350 chains.
Ok that is handy. So sprockets and idlers should all be able to be left alone then. I've heard you have chain available possibly if so can you message me some pricing on some. Thanks much for the info so far!
Correct, all you need is the chain. Not something that I have, sorry.
Users browsing this forum: No registered users and 249 guests
