Any body play around with rubber pads on 420 or other crawlers?
E.Huffman
Post by E.Huffman » Mon Oct 25, 2021 9:26 am
Hi has anyone played with putting rubber squares on top of track pads to keep from tearing things up?
Re: Any body play around with rubber pads on 420 or other crawlers?
Post by Paul Buhler » Mon Oct 25, 2021 12:17 pm
There was a member who put rubber tracks on his 420. He cut down 420 sprockets and welded on appropriate rims with teeth that matched.
A search might find his posts; they were a few years ago.
E.Huffman
Post by E.Huffman » Mon Oct 25, 2021 12:20 pm
Yea I think I saw that one. I was wondering if any one has bolted tread in between each cleat. We sometimes have tractor tires go bad and was thinkin about bolting it in it..
Post by Paul Buhler » Mon Oct 25, 2021 12:26 pm
By us there is a tire re-caper who will sell lengths of that material; which is rectangular and flat in profile. I wonder if it would work for you? Might need to be doubled to be proud of your grousers, and counter bored a bit for the bolts. Good luck.
E.Huffman
Post by E.Huffman » Mon Oct 25, 2021 3:07 pm
Yea it might. Maybe I am completly stupid for even thinking about it...
Post by Stan Disbrow » Tue Oct 26, 2021 4:24 am
There were optional rubber pads back when these machines were new.
E.Huffman
Post by E.Huffman » Tue Oct 26, 2021 5:47 am
Really! Do you know what they looked like?
Pat
Post by Pat » Tue Oct 26, 2021 6:59 am
A gentleman in Virginia did a Lindeman and now an MC. Got the pads from an industrial supply in Richmond Va. , counter sunk the rubber, drilled holes in crawler pads and now drives it around the neighborhood. If I can find the post on facebook, I will post the info here.
Post by Stan Disbrow » Wed Oct 27, 2021 4:31 am
I never saw any mounted. Just pics in the parts catalog.
fundytides
Post by fundytides » Wed Oct 27, 2021 5:47 am
Like Stan, I have never seen the actual Rubber Shoe but there are pictures of it, along with all of the other types of shoes, in my 40c parts catalog. It looks like they have a bevel around the edges and have 2 integral studs to use nuts to affix them to the pads. Can't tell the size so I don't know if they would fit on all pads or only on the "flat street type". Good luck!
Trackburger
Post by Trackburger » Wed Oct 27, 2021 6:50 am
I installed pads on my Lindeman and just recently my MC. Google search Zimmerman Oliver Cleatrac... the website will come up... hes in PA. About $8 per pad with all hardware needed. Had to have a machine shop drill 2 half inch holes in each grouser pad. Work great.
I have no idea how to post pics on here.... sorry.
Message me on Facebook Steve Palermo and ill send pics
E.Huffman
Post by E.Huffman » Wed Oct 27, 2021 1:54 pm
Hey thanks! I will check them out!!
Post by Paul Buhler » Tue Nov 02, 2021 4:56 pm
I wonder if a 2x hardwood block countersunk and bolted on would work? Are you working this machine, or using it in parades and such?
E.Huffman
Post by E.Huffman » Wed Nov 03, 2021 7:06 am
This is just a work machine its not very pretty! I could try wood I just wonder how it would hold up? Cheaper than rubber!
Post by Ray III » Wed Nov 03, 2021 2:12 pm
Do your tracks have snow holes in them? Could put a piece of steel bar through the chain underneath for a place to put an extra bolt through to secure whatever you're adding.
I've thought about wrapping a strip of conveyor belt around the entire track to make the machine road friendly. Not sure how long it would last before the grousers wore through.
