JD450 H-L-R transmission filters
LMBE
Post by LMBE » Wed Sep 29, 2021 4:55 pm
Hello All,
I want to clean the HLR transmission filter and check condition.
I have read several posts on this and did not see how to remove the cover.
I have drained the oil, removed the 3 bolts that seem to hold the filter cover on.
I do not really see what to pry on to get it to come loose, I am trying not to break anything. I have tapped on the cover, and tried to pry but no luck.
Any suggestions?
Larry
Mikeforester
Re: JD450 H-L-R transmission filters
Post by Mikeforester » Wed Sep 29, 2021 6:25 pm
Hi Larry,
Try working a small thin chisel between the cover and the case and it will come off. It is probably stuck on due to the gasket and sealant being old.
Mike
LMBE
Post by LMBE » Thu Sep 30, 2021 10:09 am
Thank you,
that was what I thought but thought I should ask before doing something stupid.
