2-53 diesel engine overhaul
carolina crawler
Post by carolina crawler » Mon Jul 23, 2007 7:17 am
HI fellow crawler friends,anyone have any info on where to get a engine overhaul kit(sleeves,pistons,gaskets, and bearings, for the 2-53 diesel...seen a kit on ebay, but not sure if thats my only source. My crawler compression is low, and between everything else, I need to freshen up the motor.planing to remove the engine completley from frame to replace main clutch,can this be done with my loader still attached to the crawler.....440icd..........Mark /CC
Post by Lavoy » Mon Jul 23, 2007 8:21 am
I sell kits for them, let me know what you need.
jac
Post by jac » Tue Jul 24, 2007 5:36 pm
Engine can be removed with the loader attached. You will have to remove the grill and radiator and then you can get the engine out. I had my engine out last year. Bucket was annoying but you can work around it without too much problem.
440icd
2-53 kits
Post by 440icd » Fri Jul 27, 2007 12:45 pm
You sell the piston and liner kits for the 2-53 Detroit diesel?
How much for a set?
I want the new style S series I believe, (more compression)
Scott in wa.
Post by Lavoy » Sat Jul 28, 2007 10:19 am
You want the N series, not S series. The kit I sold had everything in it, so was more money. If all you want is the liners, I can check on price. Send me an e-mail if you want, and I will check more on Monday.
Users browsing this forum: No registered users and 234 guests
