Can anyone tell me where the coolant sensor is located on the engine block on my JD 555G. The coolant temp. alarm goes off at different times for a short period of time. I have the Technical manual for this model but for the life of me I can't find the sensor.
Thanks for your time
555G temperature alarm
Re: 555G temperature alarm
Temperature sender switch should be on the top, left rear corner of the head. That is where most of the 4 cylinder engines were and where the parts catalog shows it. Post back if it isn't there.
Just a note that might get your question more visibility. Questions like this should be on the Late Models Board. Lavoy, or a moderator, will likely move it over there when they see it.
Users browsing this forum: dennisg and 244 guests
