steering clutch adjustment
gregjo1948
Post by gregjo1948 » Fri Apr 30, 2021 2:25 am
Working on a JD 350B. After installing new steering clutch discs, I need to adjust the pressure plate fingers and I wondered if the adjustment gauge, that I purchased to adjust the pressure plate fingers on a JD 1010, would work for the JD350B???? thanks, gregjo1948
Re: steering clutch adjustment
Post by Jim B » Fri Apr 30, 2021 7:16 am
I think the JD7 gauge works for the 350B steering clutches, but I don't have a manual to confirm that. A search of past posts indicates it is the one people were using. Lavoy, LeonardL, or others will be along to confirm or correct my thought.
Post by Lavoy » Fri Apr 30, 2021 8:41 am
Same gauge, correct.
Users browsing this forum: No registered users and 245 guests
