1973 450B pto
1973 450B pto
Hey guys, i was running my 450b today for about 3 hours. After i finished, i went and checked the pto shaft because i put a new seal in it. And boy it was hot. I mean hot hot, couldn't touch it hot. This cant be normal can it?
Re: 1973 450B pto
No dude that aint normal. I suspect you have a bearing going bad or your shaft is biding up. I wouldn't run the pto until you can figure out what's going on.
Re: 1973 450B pto
Thats what i was thinking, problem is, i cant turn it off.
If i can figure out how to disengage it, i will. Hopefully i dont have to pull the front cover off.
Re: 1973 450B pto
Well... it will mean you'll have to drain the transmission oil but you can pull the shaft from the rear of the machine. I would suspect it will be the bearing there at the rear of the PTO shaft that is bad anyway. Those bearings can be an issue. I have also ran into where the shaft will get bent slightly and cause the bearings to go bad. Usually with that condition you will have a bad vibration as well.
Re: 1973 450B pto
Can i change that rear bearing from the rear of the machine? Ill take a look at it this evening.
Can i pull the shaft out and leave it out. Maybe weld up the housing?
Re: 1973 450B pto
Back the rear of the tracks onto a RR tie or equivalent. This will help shift your oil forward away from the three bolt plate that holds the shaft/bearing. I sourced a bear plate with no shaft provisions from a breaker. This way I can pull the shaft with cover and replace the opening in the rear of the case with the proper plate.
Good luck, Bruce
Good luck, Bruce
Re: 1973 450B pto
Perfect, thats the ticket.thanks
Re: 1973 450B pto
Would the part, T122779 be the correct cover?
Re: 1973 450B pto
I agree with B Town. Item Key # 12 in this drawing.
https://partscatalog.deere.com/jdrc/sid ... gId/171637
Re: 1973 450B pto
Thanks guys.
Users browsing this forum: Jim B and 293 guests
