1973 450B pto
Riley99
1973 450B pto
Post by Riley99 » Thu Feb 25, 2021 5:06 pm
Hey guys, i was running my 450b today for about 3 hours. After i finished, i went and checked the pto shaft because i put a new seal in it. And boy it was hot. I mean hot hot, couldn't touch it hot. This cant be normal can it?
LeonardL
Re: 1973 450B pto
Post by LeonardL » Thu Feb 25, 2021 6:14 pm
No dude that aint normal. I suspect you have a bearing going bad or your shaft is biding up. I wouldn't run the pto until you can figure out what's going on.
Riley99
Re: 1973 450B pto
Post by Riley99 » Thu Feb 25, 2021 6:27 pm
Thats what i was thinking, problem is, i cant turn it off.
If i can figure out how to disengage it, i will. Hopefully i dont have to pull the front cover off.
LeonardL
Re: 1973 450B pto
Post by LeonardL » Fri Feb 26, 2021 9:00 am
Well... it will mean you'll have to drain the transmission oil but you can pull the shaft from the rear of the machine. I would suspect it will be the bearing there at the rear of the PTO shaft that is bad anyway. Those bearings can be an issue. I have also ran into where the shaft will get bent slightly and cause the bearings to go bad. Usually with that condition you will have a bad vibration as well.
Riley99
Re: 1973 450B pto
Post by Riley99 » Fri Feb 26, 2021 10:02 am
Can i change that rear bearing from the rear of the machine? Ill take a look at it this evening.
Can i pull the shaft out and leave it out. Maybe weld up the housing?
B Town
Re: 1973 450B pto
Post by B Town » Fri Feb 26, 2021 10:13 am
Back the rear of the tracks onto a RR tie or equivalent. This will help shift your oil forward away from the three bolt plate that holds the shaft/bearing. I sourced a bear plate with no shaft provisions from a breaker. This way I can pull the shaft with cover and replace the opening in the rear of the case with the proper plate.
Good luck, Bruce
Riley99
Re: 1973 450B pto
Post by Riley99 » Fri Feb 26, 2021 10:17 am
Perfect, thats the ticket.thanks
Riley99
Re: 1973 450B pto
Post by Riley99 » Fri Feb 26, 2021 11:18 am
Would the part, T122779 be the correct cover?
B Town
Re: 1973 450B pto
Post by B Town » Fri Feb 26, 2021 2:28 pm
I believe that part # is for the front of the transmission, ie front input and counter balance shafts.
I’m thinking T15070. Not for certain, please check into it.
Re: 1973 450B pto
Post by Jim B » Fri Feb 26, 2021 2:36 pm
I agree with B Town. Item Key # 12 in this drawing.
https://partscatalog.deere.com/jdrc/sid ... gId/171637
Riley99
Re: 1973 450B pto
Post by Riley99 » Sat Feb 27, 2021 7:05 am
Thanks guys.
Users browsing this forum: Jim B and 256 guests
