Hydraulic pump on 350 loader/dozer
cdunn
Post by cdunn » Thu Jan 28, 2021 9:53 pm
Would the hydraulic pump on front of engine on a 350 straight loader work on a 350 straight dozer considering
the difference in GPM.
57 420c 86 Ford 4600
67 350 dozer
66 350 loader
58 Oliver OC-4
48 8n Ford
49 Farmall Cub
Struck Mini-Dozer
gregjo1948
Re: Hydraulic pump on 350 loader/dozer
Post by gregjo1948 » Fri Jan 29, 2021 2:57 am
I would say yes. The loader pump will pump more gpm than the dozer pump but, I don't see why that would matter. I'm sure Lavoy will give you a definite correct answer.
Post by Lavoy » Fri Jan 29, 2021 8:32 am
Bolt up yes, dozer function will speed up so harder to control blade for smaller movements, only thing I can think of.
cdunn
Post by cdunn » Fri Jan 29, 2021 10:53 pm
Thanks, I might give it a try, I'll you know how it works. P
67 350 dozer
66 350 loader
58 Oliver OC-4
48 8n Ford
49 Farmall Cub
Struck Mini-Dozer
