440 icd
Jaybird
440 icd
Post by Jaybird » Thu Jan 21, 2021 6:38 pm
I have a 440icd ( w/ 8A winch) that is great. I've slowly been working on it as time permits. I'm starting the dreaded electrical. I'm in need of a starter solenoid , regulator , pushbutton starter( one that last) , switch, possibly a wire harness. Lavoy , is this something you carry?
Thanks, Jason
Re: 440 icd
Post by Lavoy » Thu Jan 21, 2021 8:43 pm
All should be available.
Jaybird
Re: 440 icd
Post by Jaybird » Wed Feb 10, 2021 7:50 pm
Does anybody have a schematic of the wiring on a 44icd? I have one for a 440 ic but not the diesel
Thanks, Jaybird
Re: 440 icd
Post by Jim B » Wed Feb 10, 2021 9:10 pm
There's one in this post that might help you. viewtopic.php?t=1816
Jaybird
Re: 440 icd
Post by Jaybird » Thu Feb 11, 2021 11:26 am
Thank you Jim. This does help. If anyone has a full schematic of the wiring please let me know.
Re: 440 icd
Post by Jim B » Thu Feb 11, 2021 6:17 pm
Just some thoughts, in case no one comes along with a 440ICD schematic for you. Do you have the parts book for your 440ICD? It shows the fuses, breakers, gauges, and switches/sending units you should have. (Here is a link to the one on line if you don't
https://partscatalog.deere.com/jdrc/nav ... VJUE1FTlRd )
The 440IC and ICD wiring is similar, it looks like the lights are the same in the parts catalogs. So that IC wiring diagram, the parts catalog and the diagram in the old post should have what you need unless you are doing a 100% restore and need wire colors to build a harness. Lavoy likely has the service manual(s), with diagrams, for your ICD available through his store. HTH
Re: 440 icd
Post by Lavoy » Fri Feb 12, 2021 8:42 am
440ICD service manual will have the wiring diagram.
Users browsing this forum: KPaXz and 170 guests
