trouble steering 350 straight
Hello been 2yrs since last visit. I have a 1966 350 straight & am having trouble with steering. Up in northern mn anyone know if this would be something a garage mechanic could tackle. I do have the service manual. Thanks
Re: trouble steering 350 straight
screamineagle,
gonna need a bit more info...
please explain just what you are doing with machine..
are you attempting to make turns?
do you have manual explaining how to adjust steering brakes etc?
that would be my thoughts from your post, tho not necessarily the problem
basically need more info
With info from the manual and the guys on this forum, I'd say yes. Most anyone with a decent set of tools and common sense, can probably handle the job.
the long & short of my problem is when in gear & moving i can pull back & both tracks stop instantly like they should. But when pulling on either one by itself i now can barely turn requires a few reverse trips to get turned either way. but occasionaly seems to grab.Is this possibly just handle adjustment or how far do i dig. Just an owner that logs with it not to familiar with how it all works so any ideas appreciated. Or maybe a mechanic out there not to far away from northern mn. The J D shops dont seem to wanna work on this old but very usefull equipment.
Okay... not sure I'm following exactly what you're saying. You said you pulled both levers and the machine stoped. Indicating that both steering clutches are releaseing and the brakes apply.
So a question or two... With both levers pulled back, what happens when you only let one lever go back forward? Do this individually one side and then the other. Do the clutches seem to be working on both sides? Both left and right?
will fire up and see tomorrow but if I remember when I release one side both tracks start to turn the released one a little more than the other but takes forever to turn But seems like if i pull one side with all I can get then will turn on a dime now and then
As long as both sides are pulling. That will tell you that both steering clutches are engaging. This sounds like an adjustment issue to me. That or something is on your brake bands. Oil or moisture. Try adjusting them first and see what you have.
Sounds to me that the clutches are releasing but the brakes are not holding. Might be adjustment, worn out brake bands(lining gone), or the brake bands are glazed over and not gripping. I agree with Leonardl, try adjusting.
ok will study up on brake adjustment & start there thanks
Thanks for info adjusted brakes and now steers like a dream
I like a success story. My 350B has been down since summer. Only driving with the left track and would really like to have used it a couple days ago when we got 41" of snow. Buried both my plow trucks and had to use a little 1620 4x4 Ford with a front bucket loader to clear my 1/2 mile driveway.
Users browsing this forum: Jim B and 222 guests
