jd440 ic
dtoots1
jd440 ic
Post by dtoots1 » Tue Nov 24, 2020 8:18 am
what is idle rpm and max rpm?
need info for crank hydraulic pump believe wants 23gpm at 2000psi..what pump needed?
Re: jd440 ic
Post by Lavoy » Tue Nov 24, 2020 11:48 am
maybe 700 idle, 1850 rated. Should be 15GPM at 1500psi for non hoe crawler.
dtoots1
Re: jd440 ic
Post by dtoots1 » Tue Nov 24, 2020 4:45 pm
i a still considering that jd440i..it has blown seals on the hydreco and wondering what cost would be for alternate pump?
it has hoe and loader....
also wonder if lesser cap pump with quick disconnects for each would possibly work?
if i can get right price for the thing.
if i recall correctly specs call for 23gpm at 2000psi
Re: jd440 ic
Post by Lavoy » Tue Nov 24, 2020 6:43 pm
Service manual is sadly non-specific, it says 1750 or 2000, but makes no specification as to which pressure correlates to which.
When I get the replacement kits done, $1000 range is my guess.
Users browsing this forum: No registered users and 215 guests
