john deere 420c Running on 1 cylinder.... Help!!
E.Huffman
Post by E.Huffman » Mon Nov 16, 2020 4:52 pm
So i have a newer (1958 or newer) 420c that i am having issues with running on one cylinder. the plugs,wires and cap/points are all good. however when we rotate the whole distributer 180 degrees it switches from the front to the back cylinder still running on one cylinder and vice versa when switched back. Any ideas on what to do we are kinda stumped! Thanks in advanced
Re: john deere 420c Running on 1 cylinder.... Help!!
Post by Jim B » Mon Nov 16, 2020 6:03 pm
This sounds familiar. Did you just replace the distributor cap? If so click this link: viewtopic.php?f=1&t=12390&p=69224#p69224 and read the thread. It's a starting point.
E.Huffman
Post by E.Huffman » Mon Nov 16, 2020 6:23 pm
I do believe this might be my issues! I have a 12 volt system with a "6 volt" cap!
Post by Jim B » Mon Nov 16, 2020 6:35 pm
Distributor caps do not care about voltage. You need a cap for a Dubuque built 2 cylinder engine which would have had a 6 volt electrical system. When you look at the cap there should be a spark plug wire terminal both sides of one clip that hole the cap on. If the plug wires are between the clips it is the wrong cap.
E.Huffman
Post by E.Huffman » Mon Nov 16, 2020 7:07 pm
Ok well if it doesent care about voltage then I am stumped because thats what i HAVE.............
Post by Jim B » Mon Nov 16, 2020 7:29 pm
A distributor cap has no primary wires going to it. The cap receives the secondary voltage (20,000 plus volts) from the coil wire in the center and the rotor button directs that voltage to the plug wire terminals. The cap does not see either 6 or 12 volts. If the spark plug terminals are on each side of one of the cap clips it is the proper cap and not the problem. If the plug terminals are between the two cap clips it is the wrong cap. Where are the plug terminals on your distributor cap in relation to the clips?
E.Huffman
Post by E.Huffman » Mon Nov 16, 2020 7:38 pm
so I have the one that has terminals on each side of 1 clip like the right one you were describing. So we even took the whole distributer assembly off our john deere 40 wheel tractor (it has the same dist) and still only one cylinder. It has become quit a frustrating problem! :?
B Town
Post by B Town » Mon Nov 16, 2020 7:57 pm
Can we have some background on the machine. Like when was the last time it ran correctly, has the motor ever been apart etc.
Best regards, Bruce
E.Huffman
Post by E.Huffman » Mon Nov 16, 2020 8:20 pm
Honestly I just bought it 2 days ago has'nt run right since I got it, how ever we turned the oil pump timeing 180 degrees and works beautiful! Thanks alot!
B Town
Post by B Town » Mon Nov 16, 2020 8:26 pm
I wondered. Someone has been in there before you and been causing problems. Glad you found it.
Post by Jim B » Tue Nov 17, 2020 5:49 am
E.Huffman,
Glad you found the cause. I went for the cap as I have been given the wrong cap before. Some parts books list the Waterloo cap as a 12 volt cap and the Dubuque cap as 6 volt. The parts person asks 6 or 12 volt and if a conversion to 12 volts was done, the answer is 12 volts. Reality is the cap doesn't change any more than the rotor, points, or condenser do with a conversion. Just curious, if the way it was running, and the previous owner couldn't fix it, was part of the reason it was available? Did you know if he had replaced the oil pump or done an overhaul, and then had this problem?
Did you check out the 430C Operator's manual? Is that the info you needed?
Good call Bruce, on asking about a the history. I was only thinking of a simple cause, like a parts guy handed out the wrong cap with tune up parts.
E.Huffman
Post by E.Huffman » Tue Nov 17, 2020 6:14 am
So It looked like it had head work done within the last 5 years but I had no idea what, the man that owned it had a brain injury and his wife was just trying to get rid of it. So when we were messing with the spark plugs we happened to look into the block and judging by the way the side wall looks in the one cylinder it has had a snapped rod in the past..... yes it has a nice big gouge in it ....... Also we noticed it has .45 overbored pistons in it. Just to be clear it does not have a snapped rod currently. Obviously I knew none of this until i got in the shop to work with it.... I think it will be ok It is definitly a mosquito killer!!!! :(
E.Huffman
Post by E.Huffman » Tue Nov 17, 2020 6:15 am
E.Huffman,
Thanks a lot for that info as I did not know that there were specific caps for the dubque tractors!!!!
dtoots1
Post by dtoots1 » Tue Nov 17, 2020 8:05 am
definitely is the wrong cap!!! you can order the correct one directly from Lavoy, owner of tis site and basically all parts needed...
i too had run into same problem, get correct cap and problem solved.
E.Huffman
Post by E.Huffman » Tue Nov 17, 2020 8:19 am
The cap I have is the right cap. I have it running great on the cap it has.
Users browsing this forum: No registered users and 196 guests
