440 gas loader coming apart
Just picked up a parts machine in pieces
Have a model 91 loader complete with cylinders $500
I am going to keep the drivetrain , will be adding other items soon.
Located in upper Michigan.
Message me if you are looking for something in particular
Re: 440 gas loader coming apart
Got any backhoe hooks? I’m in Minneapolis and have a 440ic, it has a PTO shaft without any lifting arms. I don’t know what it was for but it works. I wish there would be a threshing show this year so I could meet some folks that have one of these things.
Josey
Minneapolis, MN
440ic Rookie
Minneapolis, MN
440ic Rookie
Sorry no hooks or 3 point parts.
How about track rollers do you have any of those?
I just replaced one side completely on my dozer and i think there was 1 possibly 2 shell useable , if i remember correctly there were 3 with good pins and bushings no play , but the shells were shot. a guy could put one together if he needed one. The parts machine i would have to check the condition probably in the spring.
Also have other parts available ......Hood and front nose frame with grill,
fuel tank , loader assembly with cylinders , counterweights with mounting bracket . Deluxe seat frame , hydraulic pump .
and which hydraulic pump would that be?
Complete 91 loader for sale ......other parts available .
Michigan / Wisconsin border
need name of pump and operating valves...may need once i get mains and try mine...assume is crank pump not cam pump?
Yes it is a crank style pump I believe , it's different than my cam pump on 440 dozer.
Should have everything you need.
Am still waiting on main bearings for my 420....do you have name of the pump and valves??? Hydreco?
