Turning shaft
440 CRAWLER
Turning shaft
Post by 440 CRAWLER » Thu Jul 28, 2005 8:33 pm
Just wondering if anyone has ever turned the upper idler shaft to bring the unworn side to the top
seems like this could work ?
ggfossen
Post by ggfossen » Fri Jul 29, 2005 7:21 pm
440,
I was sort of wondering the same thing. I have two pretty much sacked out on my 420. I just don't have a big press, or I probably would have already tried. The press is on the drawing board. Right behind the 420. Carts and horses and stuff, or chickens and eggs. I never could get any of that quite right.
Gary
okie dozer
upper shaft
Post by okie dozer » Sun Jul 31, 2005 12:50 pm
Found the same problem on our 420. Obtain the upper replacement bearing. start laying in arc welder beads/mig beads roughly to the required dimension and roughly finish with a large flat file. You'll probably find the very outer end of the shaft is not totally worn down and will make a good welding guide. A mic or caliper will help. Approx 2-hours work and polishing machinist's tape finished it to a near perfect fit. good luck
Post by Lavoy » Sun Jul 31, 2005 8:52 pm
Gary,
Does not take a lot of press, they are not in that tight. I have reinstalled new shafts with a dead blow hammer.
I should have half a dozen new shafts this week sometime.
ggfossen
Post by ggfossen » Mon Aug 01, 2005 8:19 pm
That's good to know. I only tapped on it lightly, and backed away. I haven't had time to work on any of it, though. My son needed a shop, so we built that, and now we have some travelling in front of us. I hope to get back to it ernestly in September.
How much are the shafts? Bushings? This is for the upper roller.
Gary
Post by Lavoy » Mon Aug 01, 2005 9:54 pm
Shafts are $50, don't remember for sure, but bushings are $10 or less, seal is the same story.
ggfossen
Post by ggfossen » Tue Aug 02, 2005 8:11 am
Thanks for the response. I don't know, though, when I will again be belly deep in the project. I will, but I just don't know how soon. Might depend on how badly I need another road built.
Gary
440 CRAWLER
Post by 440 CRAWLER » Tue Aug 02, 2005 4:44 pm
LAVOY
HAVE THE SHAFTS ARRIVED YET?
Post by Lavoy » Tue Aug 02, 2005 6:38 pm
They are done, I have not had time to go get them, it is a 50 mile trip.
