john deere 350 dozer
bobcatt743
Post by bobcatt743 » Mon Oct 05, 2020 3:10 pm
i have a john deere 350 dozer i put new clutches in drum then put my new pressure plate on drum . I used the jd-7 gauge to set new pressure plate but run out of adjustment before the fingers get close to gauge. Im not sure why it want adjust correctly?
Re: john deere 350 dozer
Post by Jim B » Sat Oct 24, 2020 1:07 pm
I see no one has responded to you. If you haven't solved the problem yet, a bit more info might help and maybe someone else will pitch in. Is this a straight 350 and do you have the service manual?
Are you putting back the same number and type of discs? Are they all new? Are they in correctly? Does your manual give you thickness for the discs and stack height? If it does did you check those items?
This may not be your issue, but check this older post out. viewtopic.php?f=8&t=12383&p=69163&hilit ... scs#p69163
dtoots1
Post by dtoots1 » Sat Oct 24, 2020 1:15 pm
the one question i see....is where did you get the clutch packs....aftermarket may be suspect....Lavoy, the site owner does sell the proper parts for these machines...and at reasonable prices
also is good idea to add your location to your profile...in the login drop down box
Post by Lavoy » Sat Oct 24, 2020 2:23 pm
We have corresponded, his parts came from Ebay.
original possum
Post by original possum » Sat Oct 24, 2020 3:22 pm
Did you put one fiber past the snap ring? Bought a 350 cheap once because someone didn't and they couldn't adjust it.
LeonardL
Post by LeonardL » Sun Oct 25, 2020 7:30 am
Well... That answers a lot right there. I'm sure there are some good sellers who have good products on E-bay and Amazon. Finding them however is always a daunting task it seems. My experience has taught me to stay away from cheap and go with folks like Lavoy or a Deere dealer that handles aftermarket parts.
I did send this person a PM apologizing for missing their question. Like others have said, I hate it when a question goes unanswered. After contacting them I went through how to stack his clutch packs correctly. I haven't heard anything back so I hope for their sake that they have gotten them assembled and adjusted correctly.
Users browsing this forum: No registered users and 258 guests
