Track chains
Bret4207
Track chains
Post by Bret4207 » Thu Oct 01, 2020 7:16 am
Sort of researching 1010 replacements, came across this. Anyone know anything about them or the comapnay?
40C, 420C, 1010C-L-BH, Cat D4
Re: Track chains
Post by Lavoy » Thu Oct 01, 2020 9:01 am
No link shows, but there are no direct replacements, anything new will require sprocket rims.
Bret4207
Re: Track chains
Post by Bret4207 » Thu Oct 01, 2020 10:26 am
I'll try again. https://rubbertracksandattachments.com/ ... -set-of-2/ So these wouldn't be correct? A sprocket rim wouldn't be the end of the world. I assume they are probably 350 tracks?
Re: Track chains
Post by Lavoy » Thu Oct 01, 2020 1:03 pm
No, in spite of what the add says, those are 350 chains. New 1010 chains do not exist, haven't for as long as I have been at this. Those will work, you will need to purchase a set of 350 sprockets, cut the rim off of them and yours, and weld the new rim on your old centers.
Bret4207
Re: Track chains
Post by Bret4207 » Thu Oct 01, 2020 2:14 pm
Thanks Lavoy!
Bret4207
Re: Track chains
Post by Bret4207 » Sun Oct 04, 2020 6:55 am
Lavoy, looking at my drive sprockets I can see the rims appear to have been welded already. Is there a way to determine if they've been switched to 350 rings already? Couldn't find anything in a search here.
Re: Track chains
Post by Lavoy » Sun Oct 04, 2020 9:40 am
If you have a piece of 1 3/4" OD tubing, set it in one of the cups and see if it sets in there all the way to the bottom.
Bret4207
Re: Track chains
Post by Bret4207 » Sun Oct 04, 2020 10:22 am
Okay, I can do that. Would the 1010 be smaller?
Re: Track chains
Post by Lavoy » Sun Oct 04, 2020 12:18 pm
Yes, 1010 are 1 9/16".
Bret4207
Re: Track chains
Post by Bret4207 » Sun Oct 04, 2020 4:47 pm
Users browsing this forum: No registered users and 165 guests
