Engine removal 450C
8thnotch
Engine removal 450C
Post by 8thnotch » Sun Aug 23, 2020 7:44 am
450C crawler loader some of you had said remove loader frame to access everything.What is all involved in removing loader frame besides the 4 mounting pins to frame and undoing all hydraulics under the steps . Looks like the frame to hang a back hoe has to come off also but I have snapped off bolts on mine . Book shows removing hood,rad, filters etc and pulling engine forward and out what’s the easiest way for the loader crawler? Thanks again
rufustoad
Re: Engine removal 450C
Post by rufustoad » Thu Sep 17, 2020 5:45 pm
Pulling the pins and hoses should be it but it is extremally heavy so dont get a toe in the way. Remove the nose housing and I kept the rad on. I unbolt the bell housing and it should start to slide out. I actually did mine by myself. It sucks but that should tell you how easy it is.
God Bless
Todd
JWB Contracting
Post by JWB Contracting » Fri Sep 18, 2020 11:41 am
You do not need to pull the loader to pull the engine. You need to raise your loader and install a brace on a lift cylinder.
Jason Benesch
John Deere 400G With Winch
John Deere 2010 Crawler Dozer
Users browsing this forum: No registered users and 43 guests
