2010 hydraulics not responding!
MHarrison
Post by MHarrison » Sun Aug 30, 2020 8:22 pm
Hello friends, yesterday I serviced the transmission in my 2010 dozer (constant mesh) I couldn't get the blade to go up or down. What's the best way to get to the air out? Thanks in advance.
2010 Diesel Crawler Dozer
original possum
Re: 2010 hydraulics not responding!
Post by original possum » Tue Sep 01, 2020 7:44 pm
Looks like you are new to the board and possibly new to your 2010. The blade hydraulic system is separate from the transmission. If it is not responding either the hydraulic oil level is low, the pump is disengaged or has failed, or there is some other cause (which should be more obvious). But if you have air in the lines the best way I've found is to hold the control in the "lower" position until it lifts the tractor and stops lifting, then raise the blade and hold the control in the "raise" position until the blade is fully up for a few seconds. Then repeat. If you push the control too far toward the "lower" position and nothing happens you are in the "float" position and nothing WILL happen other then the blade falling to the ground.
Post by Lavoy » Wed Sep 02, 2020 8:10 am
Yours must have the rear pump? Not sure why it won't prime, that is unusual. Make sure no obstruction in the suction line is one thought, but no reason that should have happened.
MHarrison
Post by MHarrison » Wed Sep 02, 2020 5:05 pm
The pump is engaged and the oil level is correct. Still nothing. Would the transmission screen being stopped up have any effect on the hydraulics?
Post by Lavoy » Thu Sep 03, 2020 7:44 am
I don't know for sure. I assume hyd pump has its own inlet.
gus
Post by gus » Fri Sep 04, 2020 2:55 pm
Can the bypass or pressure relief valve hang open?
Post by Lavoy » Fri Sep 04, 2020 3:45 pm
No, spring would have to break.
Users browsing this forum: Jim B and 137 guests
