1010 crawler tracks - cleats or grouser options
cmineo
Post by cmineo » Tue Aug 11, 2020 2:06 pm
do you know if there are appropriate grouser attachments or cleats that can be used on 1010 dozer tracks. my tracks are worn and im thinking of adding teeth or something to them
or can i source a different track set up
Re: 1010 crawler tracks - cleats or grouser options
Post by Lavoy » Tue Aug 11, 2020 4:33 pm
Do you have a loader or dozer? Grousers on a loader are very hard on stuff. If you have a dozer, grouser stock can be bought and welded on, or replace the pads with new.
cmineo
Post by cmineo » Tue Aug 11, 2020 4:58 pm
loader. mine has the oem bucket ... i read that with the added weight from a bucket full grousers can actually add serious strain on the rollers .... but im not sure if that was correct so i posted here.
i am worried about traction in muddy or loose hillside dirt, so i was actually wanting to add pads or something that wont damage the undercarriage
gregjo1948
Post by gregjo1948 » Wed Aug 12, 2020 3:48 am
As Lavoy stated, grousers will be harmful to the undercarriage. All the weight out front with the weight of the bucket and the payload in the bucket, tries to stand the machine on its toes. Then when turning, while standing on its toes, grousers are having to twist the soil under them. Very tough on the front idler and roller. The extra weight, just going straight, is tougher on the bearings in the rollers and front idlers.
Users browsing this forum: No registered users and 192 guests
