Hello all, new here to the forum, 1010c
bronc0419
Post by bronc0419 » Fri Jul 31, 2020 8:51 am
Hello all,
I just purchased a 1010c, 1961, diesel, 6 way blade, with 14" tracks. Had it running and moving forward and reverse, hydraulics worked, so now I am figuring out what parts I'm going to need. I see there is a vast amount of info on this site. I already purchased the Operators, Parts and Tech manuals so I can track down filters and recommended fluids.
One question, and forgive me I haven't searched through the board yet, I would like to change the oil bath air filter to a regular style air filter, is this an easy task, has someone already done this?
Thanks and looking forward to taking part in the board.
Ken
Re: Hello all, new here to the forum, 1010c
Post by Lavoy » Fri Jul 31, 2020 5:17 pm
No conversions so to speak. If you can find a real high serial number diesel (>42,000) you can rob all of the air cleaner components off of it. Beyond that, the oil bath works fine, no drawbacks other than change the oil once in a while.
bronc0419
Post by bronc0419 » Wed Aug 05, 2020 9:16 am
Thanks for the info Lavoy, working through a few issues, will start up and run for a few minutes then quit, looking at the fuel system right now to see if the pump and injectors need rebuilt.
roadburner
Post by roadburner » Wed Aug 05, 2020 4:48 pm
Check the fuel line to the tank and filters. Pump may be starving for fuel.
broncO419 do you own a Bronco?
Users browsing this forum: No registered users and 186 guests
