lubricating my undercarriage on my 40C
Emzed
Post by Emzed » Fri Jun 26, 2020 11:45 pm
Just got the correct grease gun fitting to lube my undercarriage on my 40C. I have heard I need a special low pressure grease gun. Where do I get something like this? Also, what grease or wt oil to use? Thanks. Mz
Re: lubricating my undercarriage on my 40C
Post by Stan Disbrow » Sat Jun 27, 2020 4:13 am
Lavoy has the low pressure guns. The JD Ag dealer has the Corn Head Grease you need to use. Buy many tubes as you likely will need to put a lot in.
Whoops! Never mind! OP has the earlier rollers! Read on:
original possum
Post by original possum » Sat Jun 27, 2020 10:50 am
How many rollers, three or more?
Emzed
Post by Emzed » Sat Jun 27, 2020 9:38 pm
Thanks!
Emzed
3 roller
original possum
Post by original possum » Sun Jun 28, 2020 10:20 am
A 3-roller uses "heavy gun grease" in a standard grease gun. Fifteen pumps every ten hours by my book.
Post by Lavoy » Sun Jun 28, 2020 9:40 pm
No need for low pressure gun on a 3 roller, but the guns I have are also high volume which works great for 3 rollers.
Get the stickiest heaviest grease you can find.
Emzed
Post by Emzed » Sat Jul 04, 2020 6:08 pm
Thanks all.
Rollers greased except one with bad button head fitting. Ordering a new one and spares.
Where is the fitting for the front Idler wheel?
Mz
original possum
Post by original possum » Sun Jul 05, 2020 1:49 pm
Should be a button-head fitting on the hub between the spokes. You may have to move the track several pads to see it.
Emzed
Post by Emzed » Mon Jul 06, 2020 10:14 am
Found them, as you noted they were out of sight due to how the idlers were rotated thanks!
Mz
Users browsing this forum: Google Adsense [Bot] and 262 guests
