drive sproket removal
kmdfarm
Post by kmdfarm » Fri Dec 06, 2019 7:03 pm
how the heck do i get the drive sproket off my 440 loader wont come off with it hitting last roller do i drive the 3 bolts that are in the flange?
original possum
Re: drive sproket removal
Post by original possum » Sat Dec 07, 2019 12:40 pm
This is over 56 years of memory talking and may not be accurate. I recall using a bottle jack and chain as a puller to get it off the three dowels after the bolts are loosened a lot but not removed. That and a sledge hammer usually worked, assuming the axle bearings were still good.
Post by Lavoy » Sun Dec 08, 2019 10:40 am
It should come off without hitting anything. Try rotating it a little bit, see if a different position lets it off the studs.
kmdfarm
Post by kmdfarm » Sun Dec 08, 2019 7:30 pm
believe me ive tried every way and it wont clear the roll!! whats up with that? makes no sense why would they build it like that should i try driving the 3 bolts out of the flange or what? driving me nuts
bent
Post by bent » Mon Dec 09, 2019 6:08 am
kmd the outside of the sprocket teeth should run in the centre of the back roller but not so close as to bind like that. There should be enough clearance to get the sprocket moving off the dowels. Some things that might be happening - is the axle moving outboard with the sprocket? That would mean the retainer bolts on the inside bearing have been removed or are damaged allowing the axle to move. Can you move the axle (in and out)? Is the outboard final drive bearing failed and allowing the sprocket/axle to "twist"? What about the roller? Is it twisted due to its bushings being shot? Something isn't right. Any pics?
Post by Lavoy » Mon Dec 09, 2019 9:22 am
I agree with Brent, there is something up, they are not designed like that, and I have never had one that would not come off for that reason.
kmdfarm
Post by kmdfarm » Wed Dec 11, 2019 6:22 pm
cannot find whats wrong with it obviously something nothing loose or out of place so i finally drove the studs out of the flange to get it off putting it back on will be another days problem do all 3 have to be there with the other bolts holding it on
Post by Lavoy » Wed Dec 11, 2019 7:41 pm
Yes, the bolts will not hold by themselves.
Users browsing this forum: No registered users and 185 guests
