I need to replace my ring & pinon gear set PN AT18842 in my 350 straight Crawler loader with a reverser and a transmission that has a revers gear. I have a spare transmission without a revers gear that has a broken case at the upper LH mounting bolt & worn input shaft in the area of the coupler. The rest is in good to usable condition.
Are the ring & pinion sets interchangeable from these two transmissions? If I remember correctly the Transmission without revers maybe from a 350C.
ring & pinon gear replacment 350 straight
northidaho
1967 JD straight 350 crawler loader with 4&1
Users browsing this forum: No registered users and 36 guests
