JD450C radiator availabilty
My 450c popped a big hole in the radiator upper tank today. I know I can pull it and get it acid washed, cored and brazed at a good shop I have used before. But I looked for a new one, and all I found were $1,200 or more! It is a JD part number AT39009. Is there a crossover list somewhere that might have a different one that would work for less?
If no luck new I'll just get it fixed and drive on.
Thanks all!
Thanks all!
Re: JD450C radiator availabilty
JDParts says a AT116777 Radiator is the same thing as the AT39009.
I didn't look long but the cheapest I saw was 1500. Ouch, if fixing is an option....
As psprague posted the JD parts catalog AT39009 subs to AT116777 now. I see prices of about $2130. from the sites of the two dealers I use. If you have a radiator shop that does good work and you trust; I would be looking hard at them doing a repair/re-core if it was mine. There might be some cheaper aftermarket radiators out there but who knows the quality, fit, or cooling capacity. I see a lot of posts on other sites from guys not happy with aftermarket radiators they have purchased due to one or more of those things. Send Lavoy an email (postmaster@jdcrawlers.com) and see if he can help you. If he has an aftermarket radiator, I would trust one from him.
I have a 450 plain and I just had my radiator re-cored at a local rad shop for 885.00 including 7% sales tax. After about 2 weeks searching on internet the least I found a radiator for was 1500.00.
Ouch! I'm afraid that's what I will end up with. Gotta have it working so I will start pulling that radiator this weekend....
Detroit Radiator best prices around stores all over the us they do recore .also check stinier tractor handle mostly agg but most cross to industrial
JIM
JIM
Many thanks for the leads for radiator! I will work them all and also try the bubble gum trick...
I'll post my results when they happen.
Got it fixed at Cookeville Radiator for $100 and will pick it up this week i hope. Its a 2 hour drive.to get it, but worth it. They do great work on vintage radiators and I know it will work for years to come.
Users browsing this forum: No registered users and 35 guests
