1988 350d dozer
Baron69
1988 350d dozer
Post by Baron69 » Mon Sep 23, 2019 5:17 pm
How much fluid is in each final drives, transmission and clutches?
Re: 1988 350d dozer
Post by Jim B » Tue Sep 24, 2019 6:52 am
Welcome to the forum.
I don't have the capacities for you, hope fully someone will help you. I would suggest you send Lavoy an email at postmaster@jdcrawlers.com and ask him if he can supply an Operator's Manual for your machine, from the line he carries in his store. For reference the JD part number is OMT105029. The operator's manual will have the lubrication info along with common adjustments, etc., operators need. You might want to consider getting a technical manual as well JD p number TM1115, for reference. HTH
CatD8RII
Re: 1988 350d dozer
Post by CatD8RII » Sat Sep 28, 2019 10:31 am
Can't remember the exact amount, (it's in the manual) but they are all a common sump, or 1 capacity.
You can speed the process up by using the bung plugs on the clutch housings, but the level is checked via the transmission dipstick.
