JD 2010 engine parts?
gunnutbmg
Post by gunnutbmg » Sun May 13, 2007 10:44 pm
I need a rebuild set for a 2010 gas engine ser.# 314xxx need all bearings and seals, gaskets, rings and liner seals . the crawler ran last about three years ago. and set since. the liner seals must have let go because the antifreeze is now in the oil pan. no one has tried to start it but don't know the extent of damage yet. if anyone has a good diesel for a 2010c i would like to swap it out . give me a price or reply and i will get back with you p.s. love the site thanks TIM.
Post by Tigerhaze » Mon May 14, 2007 7:38 am
FYI- Lavoy has said in previous posts that there is some work to convert 2010 crawlers from gas to diesel and diesel to gas.
http://www.jdcrawlers.com/messageboard/ ... gas+diesel
Post by Lavoy » Mon May 14, 2007 8:06 am
Should be no problem, I would need to know bearing size and ring size in case it has been bored.
If you want to go deeper into it, I can get rebuild kits with .045 over pistons if you want to bore the deck out.
gunnutbmg
Post by gunnutbmg » Mon May 14, 2007 10:38 pm
i will try to get it out this week to get the sizes of rings and bearings thanks lavoy and to tigerhaze if it were easy my kids would do it for me. ha. ha. :D thanks TIM
Users browsing this forum: Google [Bot] and 232 guests
