2010 steer clutch assembly problem
signweld@yahoo.com
Post by signweld@yahoo.com » Wed Jul 10, 2019 6:29 pm
Hi all. I am replacing My 2010C steering clutches and cant get the clutch assembly to come out far enough out to seat snap ring because it is hitting against the casting. I'm lacking less than 1/4" to get the snap ring in correct place. Mine has the 3 pins and tapered end set screw. I am assuming that the snap ring goes into the recess on the end of the clutch driving shaft, and the set screw holds tension on it ( or am I seeing it wrong?)
When I assembled clutch with a metal plate first and continued fiber / metal stack in the same pattern as it came apart. The serial # is 38193. I am going by page SM 2037 2-64 at bottom of page, figure 150-15-2-Exploded view of steering clutch. I measured how far the shaft went in without the clutch in, and get the same dimension with the clutch in. Where am I going wrong?
Paul Morrison Western NY.
gregjo1948
Re: 2010 steer clutch assembly problem
Post by gregjo1948 » Thu Jul 11, 2019 3:36 am
Are you using the correct number of metal/fiber discs?
signweld@yahoo.com
Post by signweld@yahoo.com » Thu Jul 11, 2019 1:58 pm
Yes, 8 of each just like came out of it.
Paul Morrison
signweld@yahoo.com
Post by signweld@yahoo.com » Thu Jul 11, 2019 3:46 pm
After carefull measurements I am sure that the shaft IS going all the way in. I will pull clutch assembly (AGAIN) and dis-asemble it to see what wont let hub come out over the snap ring
Paul
gregjo1948
Post by gregjo1948 » Fri Jul 12, 2019 4:05 am
Paul Morrison
I'm not sure but, I'm thinking there should be 8 fiber and 7 steel. Seems like if you have 8 steel you'd end up with steel riding against steel at one end of the "clutch pack".
gregjo1948
Post by gregjo1948 » Fri Jul 12, 2019 4:13 am
Paul Morrison
MY Wrong!!! After checking JD parts list, I see that the 2010 does use 8 of each. I guess I was thinking of the 450 which, I think uses 8 and 7.
signweld@yahoo.com
Post by signweld@yahoo.com » Fri Jul 12, 2019 8:48 am
Yes, the first steel plate goes against the steel inside the brake drum.
signweld@yahoo.com
Post by signweld@yahoo.com » Fri Jul 12, 2019 1:47 pm
SOLVED. IM RUNNING ON STUPID. There was a part in the deep hole going into the differential. It was a short heavy spring with a disc on each end.
Didn't see it with the flashlight. found it with a magnet.
Paul Morrison
dtoots1
Post by dtoots1 » Sat Jul 13, 2019 8:57 am
i assume that spring had something to do with applying tension to the shaft for that quarter inch? i haven't pulled 2010 steering tho may have to in future.
signweld@yahoo.com
Post by signweld@yahoo.com » Sat Jul 13, 2019 12:36 pm
That is what I think too. I also wondered why the elaborate setup instead of just the spring. I also see in the manual where it says "push shaft into position against the spring and tighten setscrew to lock snap ring in place"
2010OWNER
Post by 2010OWNER » Sun Oct 06, 2019 5:46 pm
Steel plate 1st is correct for serial #'s below 42001. 42001 and above, composition facing goes in first, against the brake drum, followed by alternating steel plates and composition disks.
'63 2010 Dozer, '44 Model B Tractor,'65 2010 Tractor, '55 40c crawler, '77 2240 Orchard Tractor.
