350 B Reverser
Re: 350 B Reverser
I guessed correctly because I had a 350B with a bad coupler and I had a 350 with a bad reverser. Lavoy helped me with parts.
- Jason37756
Re: 350 B Reverser
If that's the input shaft to the trans., I think I'd replace it and be sure, when mating the trans and reverser, as you're putting the machine back together, you get them completely pulled together. I use lock tight to ensure the bolts stay tight too. If the housings aren't pulled tight all the way around, it misaligns the shafts where the coupler is and that is when it strips splines.
- Jason37756
Re: 350 B Reverser
Yeah I'm really dissatisfied with how that looks. It has one tooth broken on the bottom side of the shaft as well. That will need to be replaced.
- Jason37756
Re: 350 B Reverser
Thanks!
I wanted to follow up and say thanks for all the help and advice. I got the crawler back together this week and she is now under her own power again. The reverser works perfect the transmission shifts well and both finals brake and disengage properly! The clutches surprised me because it has been setting outside for about 5 years. This is usually a death sentence for the clutches. It does have a ROPS as well as both clutch housing covers, so these defiantly made the difference.
I don't believe the power assist steering works because I can't tell any difference between my straight and the 350 B.
Thanks again guys! I'll try to do my part and pass it forward.
Jason
Jason
Users browsing this forum: No registered users and 240 guests
