Dozer blade
KCpatrol
Dozer blade
Post by KCpatrol » Thu Apr 11, 2019 11:42 pm
Will an outside dozer blade from a 1010 fit a 420 ?
Re: Dozer blade
Post by Lavoy » Fri Apr 12, 2019 9:27 pm
Yes and no. It will if you have the weld on trunnion plates for the trackframes. Then the 1010 trunnions will bolt on anc you are good to go.
KCpatrol
Re: Dozer blade
Post by KCpatrol » Sat Apr 13, 2019 7:50 pm
Thanks Lavoy. What exactly are you referring to as the trunnion plates? I don’t see anything in the parts manual called as such.
Thanks.
Re: Dozer blade
Post by Stan Disbrow » Sun Apr 14, 2019 4:28 am
The trunnion plates are integral to the later trackframes. They have four holes to mount the trunnion pins, which the outside blade frame hooks to so it can pivot. Since the 420 does not have such as part of the trackframe, you have to add them.
KCpatrol
Re: Dozer blade
Post by KCpatrol » Mon Apr 15, 2019 10:45 am
Thanks for that clarification. I assume these trunnion plates would have to be custom fabricated or can they be sources otherwise?
Re: Dozer blade
Post by Lavoy » Mon Apr 15, 2019 8:46 pm
Obsolete, fan only.
Users browsing this forum: Google Adsense [Bot] and 274 guests
