bdbundy35,
To get your post away from the 2016 one you posted your issue on (viewtopic.php?f=8&t=10786); I have started this one to continue your problem on. Have you had a chance to look closely at your pump drive as a follow up to the previous posts? Does it have all the splined shafts shown in the parts breakdown or is the engine end smooth like a pipe on the outside? If it looks like a pipe on the engine end, it is possible someone upgraded it to the newer style drive shaft.
bdbundy35 - Dozer Hydraulics
Re: bdbundy35 - Dozer Hydraulics
Saw your post on the earlier thread. So is it working now or still no hydraulics? If working what was the problem/fix?
Users browsing this forum: Bing [Bot] and 285 guests
