40c 5 roller
tldec50
40c 5 roller
Post by tldec50 » Sat Mar 23, 2019 11:46 am
I have a 40c with 14 inch pads and deep dish drive wheels.I have a question on the track pins.They are all the same with no master pins.The pins are 1.19 inch diameter on the ends that are pressed into the track chain.I can not find any numbers to posibaly cross reference to find a master pin to put back in the track. Anyone run into this on these crawlers?The correct 40/420 pins are a lot smaller.
Re: 40c 5 roller
Post by Lavoy » Sun Mar 24, 2019 11:23 am
Not sure what you have, but not factory. Might be 350 chains, but they are 1.125 pin diameter.
tldec50
Re: 40c 5 roller
Post by tldec50 » Sun Mar 24, 2019 12:50 pm
After hours with a wire brush found the name of berco stamped in a chain link,also a pin stamped 1065 i am guessing that is a hardness stamp.searched online found a phone# for berco will give them a call tomorrow.thanks for the reply Lavoy.
gregjo1948
Re: 40c 5 roller
Post by gregjo1948 » Mon Mar 25, 2019 2:40 am
The 350 also has a master pin.
Re: 40c 5 roller
Post by Stan Disbrow » Mon Mar 25, 2019 3:39 am
350 master pin looks like the rest, except for a dimple on the end. It isn't as obvious as a 420 master pin. But, to be on a 420, there needs to be a rim sprocket welded onto the 420 sprocket dish (the original 420 teeth are cut off and the 350 rim sprocket welded on).
Users browsing this forum: No registered users and 187 guests
