JD 550 Converter Seal and Winch Shaft
LewM
Post by LewM » Tue Dec 18, 2018 2:28 pm
I'm rebuilding my 550 after rod bearing began talking and rebuilt clutch packs while engine was out. Good thing I did, reverse clutches were toast and third gear clutches we're much better, 2nd had wear also. Replaced all clutches disc and about half the steel ones, all sealings rings and piston rings. Big job but fun well at least interesting.
Question 1: converter seal was not leaking but I don't want to go back in, should I change it? Cost about $200, not cheap!
Question 2: winch shaft is bent and has been rubbing against something, can it be straightened?
Thanks for the help!
Lew
JD 550 dozer, Case 1845c skid steer, Case IH 5140 tractor, Case IH 5130 tractor, Case IH 80 tractor, Kioti 3054 tractor
B Town
Re: JD 550 Converter Seal and Winch Shaft
Post by B Town » Tue Dec 18, 2018 7:54 pm
I would change the seal.
What winch model? What is the part number of the shaf the is bent?
Best regards, Bruce
B Town
Post by B Town » Tue Dec 18, 2018 7:55 pm
What winch model? What is the part number of the shaft that is bent?
Best regards, Bruce
LewM
Post by LewM » Wed Dec 19, 2018 7:07 am
I'm not sure of the model number of the winch but the part number for the PTO shaft is T41213. I'm pretty sure it is the winch that came on it. It' look just like the one in the parts diagrams.
Thanks,
Lew
B Town
Post by B Town » Wed Dec 19, 2018 7:56 pm
Winch is likely a 3325 model. I don’t see why the T41213 shaft could not be straightened in a good press.
Best regards,
Bruce
Users browsing this forum: Google Adsense [Bot] and 265 guests
