450 straight transmission
Randynscottsboro
Post by Randynscottsboro » Tue Oct 02, 2018 5:48 pm
I have a 450 straight with collar shift transmission I need parts for it that I can not locate. I found a good complete 450B trans and rear complete that has had a fresh rebuild. Would it be a direct replacement into a straight 450 machine? I know how much work is involved but this machine is useless without reverse working.
Randy
2130 HFWD
1120 JD
Case SC
1846 Case skidsteer
2030 JD
450 JD
350 Case crawler
3110D Yanmar
Mikeforester
Re: 450 straight transmission
Post by Mikeforester » Tue Oct 02, 2018 6:43 pm
I think trying Lavoy would be the first option since he sells parts to keep this site running.
Now, just thinking outside the box here, a lot of old Deere equipment shared parts with ag equipment. (I had a 68 John Deere skidder that shared a lot of parts with 3020 and 4020 tractors. Literally all the internal transmission parts were the same as a 3020. Maybe there is a similar crossover with your machine?) Maybe? It might be worth some time on the jdparts website looking around.
I cannot speak on bolting up a different transmission to your tractor.
Good luck getting the old girl up and running!
Post by Lavoy » Tue Oct 02, 2018 11:17 pm
While the later trans might bolt in, there would be a lot of other incidentals that would have to go in at the same time would think. Especially when going from a gear drive to an HLR. Direct bolt in and go, I highly doubt.
Users browsing this forum: No registered users and 279 guests
