Reuse Head Gasket?
jd440
Reuse Head Gasket?
Post by jd440 » Sat Apr 21, 2007 2:49 pm
I know that with motorcycles if the head gasket looks good, it can be reused. Is this the same with the 2-cylinder John Deeres?
I'd rather not spend extra money putting the engine back together, as I will be doing a full rebuild on it after my shop is built.
Thanks,
Derek
Jimmy in NC
Post by Jimmy in NC » Sat Apr 21, 2007 7:59 pm
I don't think I'd try it. I know that the gasket will form to the particular surfaces. Any time you disturb it I would think that's way too much possibility of a leak.
I know that a head gasket wouldn't be where I'd try to cut corners personally. I am curious if anyone has tried and what kind of results they have had.
Jimmy in NC
Howard Yoder
Post by Howard Yoder » Sun Apr 22, 2007 5:39 pm
I tried that on a 283 chey engine when I was broke and 14 yrs. old and it was a disastor. I'm older and a little wiser and still broke but I still woudn't try it. just my 2 cents worth.
Stretch
Post by Stretch » Sun Apr 22, 2007 5:46 pm
I wouldn't :!:
2010C Dozer, 2010C Loader
jd440
JD440IC Head Gasket
Post by jd440 » Sun Apr 22, 2007 7:29 pm
I'll put in an order for a full gasket set with Lavoy.
Thanks for the comments.
Derek
Users browsing this forum: No registered users and 169 guests
