jdeere 450e oil pan
lpbaker@twlakes.net
jdeere 450e oil pan
Post by lpbaker@twlakes.net » Thu Jul 19, 2018 1:40 pm
Trying to get the oil pan on my dozer off without pulling the nose.I have the belly pan off and the oil pan broke loose but cant find a way to get it out of the machine.Trick here or what?????
gregjo1948
Re: jdeere 450e oil pan
Post by gregjo1948 » Sun Jul 22, 2018 3:58 am
A little more info might help. Does the pan drop down to the ground or do you have the bolts out and it doesn't come loose from the engine?
jwbcontracting
Post by jwbcontracting » Sun Jul 22, 2018 6:45 pm
You have to pull the hard nose. You are most likely held up on the oil pump sump. Never tried with the hard nose attached. There is only 6 15/16” headed bolts and comes off easy with a shop crane.
Users browsing this forum: No registered users and 35 guests
