My friend is working on his 1010 and needs the two seals that the track adjuster piston needs.
Seems there's a piston/plunger seal on the end of piston and a wiper seal in the housing.
Local JD dealer says they can't get them.Lavoy and others any ideas?
Thanks.
Cooter
adjuster seals
- 1954cooter
Re: adjuster seals
Two different styles, one leather, one is quad ring. I should have both on hand.
- 1954cooter
Re: adjuster seals
Thanks Lavoy,
seems that I read that there are different diameters?
Will get diameter anyway and will check on type of material used.
The wiper seals are all the same?
thanks,
Cooter
thanks,
Cooter
Re: adjuster seals
No difference in diameter on OEM. There are differences in wipers, but that is a serial number deal.
Users browsing this forum: KPaXz and 190 guests
